OOM-9
Jan 06, 2012NETGEAR Expert
Domain Join Issue - Information
I have found some helpful information for people that have issues joining the domain. The points to check when configuring the ReadyNAS to join the domain, and an additional option with logs to see wh...
mjwise
Apr 12, 2015Aspirant
terryvella wrote: Hi, firstly please excuse me if I'm posting incorrectly here. I have 2 x ReadyNas 2120 and 1 x 104 all of which are successfully authenticated on my domain. The problem I have though is with the 104; it fails the ADS accounts refresh and says "Import Error" Under Authentication. All the AD users are available but only one group is imported; "Domain users". The 2120's are not affected
All three boxes are running 6.2.2 and are configured the same as each other as far as I can see but whatever I do I can't complete the authentication process without the import error on the 104. The two 2120's authenticate correctly and all 3 synch their times with the same server.
Any pointers?
Thanks
For what it's worth, I get the same error with a 516 on 6.2.2 if you run the ADS refresh. "Domain Users" is the only group that shows up as imported. That's basically the only group we use, so it's not a big deal, but AD support seems half-baked at best under 6.2.2.
