remuald
Jul 10, 2012Aspirant
Downgrade ReadyNas NV+ v2
Hi, I want to downgrade my ReadyNas NV+ v2 5.3.5 to 5.3.4 or less, because my hard disk WD30EZRX is not supported by this firmware 5.3.5. My config : Modèle: ReadyNAS NV+ v2 Série: 2V02...
PapaBear1
Jul 10, 2012Apprentice
While I do not have a NV+ v2 (or a Duo v2) to experiment with or tell you the exact steps, you should be able to download version 5.3.4 onto a local PC. Then you should be able to perform the upgrade locally rather than remote (which downloads from the server).
If you still have access to your data, I would back it up completely before you did anything.
