remuald
Jul 10, 2012Aspirant
Downgrade ReadyNas NV+ v2
Hi, I want to downgrade my ReadyNas NV+ v2 5.3.5 to 5.3.4 or less, because my hard disk WD30EZRX is not supported by this firmware 5.3.5. My config : Modèle: ReadyNAS NV+ v2 Série: 2V02...
PapaBear1
Jul 10, 2012Apprentice
You can only downgrade by using a local upgrade. That has been the case across all models. The remote will only pull down the most recent version. It's not that bad. If you need the link to 5.3.4, I will find it for you.
