remuald
Jul 10, 2012Aspirant
Downgrade ReadyNas NV+ v2
Hi, I want to downgrade my ReadyNas NV+ v2 5.3.5 to 5.3.4 or less, because my hard disk WD30EZRX is not supported by this firmware 5.3.5. My config : Modèle: ReadyNAS NV+ v2 Série: 2V02...
PapaBear1
Jul 10, 2012Apprentice
I don't know about SSH. Are you clicking the "check for updates" button? That only works for remote update, not local which is what you want. I will have to PM someone who has an ARM based unit to try to join this discussion. As I said, I do not have one of these, but page 72 of the manual talks about the local update so it should be possible.
