remuald
Jul 10, 2012Aspirant
Downgrade ReadyNas NV+ v2
Hi, I want to downgrade my ReadyNas NV+ v2 5.3.5 to 5.3.4 or less, because my hard disk WD30EZRX is not supported by this firmware 5.3.5. My config : Modèle: ReadyNAS NV+ v2 Série: 2V02...
Charles_R
PapaBear wrote: I will have to PM someone who has an ARM based unit to try to join this discussion. As I said, I do not have one of these, but page 72 of the manual talks about the local update so it should be possible.
Local update should work fine... are you saying the NAS checks/reads the local file and rejects it? Perhaps you can't downgrade if so... a driver (or whatnot) could have been updated that won't work with the older release.
