paulies's avatar
paulies
Drive DEAD ?? Drive or readynas
Hi,
I have a readynas Ultra 2 with 2 3tb Western digital hard drives, last night the readynas reported one of the drives were dead.
I have run the drive through western digitals own software (Extensive test) and the drive reports fine, so when I put it back in the readynas it goes through the sync process and at the end reports drive is dead again :(
Is the the drive failing and WDC software does not pick it up or is the readynas going to die on me.
The system has worked perfectly for years with no real need to mess.
Anybody shed any light on this ?
Thanks Paul
  • Hi
    Here are the smart stats
    Model: WDC WD30EZRX-00MMMB0
    Serial: WD-XXXXXXXXXXXX
    Firmware: 80.00A80
    SMART Attribute
    Raw Read Error Rate 0
    Spin Up Time 6491
    Start Stop Count 43
    Reallocated Sector Count 1
    Seek Error Rate 0
    Power On Hours 13070
    Spin Retry Count 0
    Calibration Retry Count 0
    Power Cycle Count 41
    Power-Off Retract Count 31
    Load Cycle Count 1636992
    Temperature Celsius 41
    Reallocated Event Count 1
    Current Pending Sector 0
    Offline Uncorrectable 0
    UDMA CRC Error Count 0
    Multi Zone Error Rate 0
    ATA Error Count 0
    The reallocated sector has been there since the drive was new several years ago.
    Thanks Paul
    Sent from my W100 using Tapatalk 2
  • StephenB's avatar
    load cycle count seems quite high given the age of the drive, though that may be an EZRX thing. My NV+ has WD20EARS with ~2x the power-on hours and ~330k load cycle counts.
    LCC shouldn't cause a diagnostic to fail though; I agree this looks ok.
  • Could the readynas guys fix this or am I just getting another drive ?
  • StephenB's avatar
    You'll never know unless you enter a support case at support.netgear.com That might not be free (depending on the warranty status).
    My fear would be that the new drive will fail in the same way. If the 4 TB is not on the HCL for the ultra, that will shut the support door.
    One thing you might try is using the write zeros test in lifeguard (the fast one). That would wipe the partitions. Then reinsert the drive with the NAS running, and see what happens.
    Another thing you could try is to shutdown the NAS and unplug it for a bit. Sometimes that resolves low-level bios glitches.
  • Hi
    That's my worry, if I buy another drive and have the same problem I could get the same drive as above but I'm paranoid if I plug it in I'll get the same problem and wasted my money.
    Even though the hard drive tested OK and my spare drive worked fine I still don't which one is faulty :( has or drive.
    The easiest solution would be get another drive that does not cost as much as another nas
    Sent from my Nexus 7 using Tapatalk 2
  • I assume you're asking because you already have one?
    Can the drive be removed easily?
    It won't be on the HCL, I'm pretty sure of that.
  • Hi
    No I don't already own one just thought someone might know what model of Seagate drive was in this. I have found this quite cheap else where was thinking if giving this a try
  • Paulies, just so you know you'll have zero warranty on the drive outside the enclosure. I purchased 3Tb drive from Digitalet at Amazon and both drives, which should have had 2 year warranties, had faulty warranties. One was an OEM drive, possibly pulled from an enclosure or mass sold--NO Seagate Warranty. The others warranty was already started with only 16 months left on it. Both ST3000DM01 are reporting DEAD in the NAS in under two years. All my other Seagate models are still golden.
    Seagate has started to confuse their models so they can change designs/specs without changing model numbers. It is getting harder to know what you are buying, regardless of the model listed.
    Thanks for the advice, in the end I have bought myself a Toshiba drive and its working a treat so far I just hope it carry's on working.
    Paul
ProSupport for Business
