TomBlack
Sep 28, 2017Guide
Drive Info Truncated on Admin Screen
Firmware 6.8.1
Drive Info on the Admin Screen System/Performance/Internal is truncated on the left side. Seems there is plenty of room to expand this field to show all drive info.
- evan2NETGEAR Expert
We need to conside all models,
for some models, they have more FAN and PSU,
there is not plenty of room to expand this field to show all drive info,
Anyway, I will report it again.
Thanks.
Netgear could of course put the status information (size and temp) in a line below the drive, which would free up the needed space. Or only report temp in C or F, not both (user configurable).
Note if you hover over the green ball icon next to the drive, you will see the full information (and the serial number).
- TomBlackGuide
Seems to me there is space to expand that one field to the right by 10 characters or so and not truncate or lose any info.
- SandsharkSensei
If you got rid of the silly animated fan and thermometer pictures, there would be plenty of room.
