JimCH1
Dec 28, 2012Aspirant
Duo drops off network after boot
Help required please! I’m having trouble with my ReadyNAS Duo RND2000 v2. After a few years of trouble free service, my ReadyNAS became unreachable a while ago, so I tried a few actions suggested o...
Dec 28, 2012Guru - Experienced User
I'd try the on-line support w/o the maintenance agreement, and see what they do. You could also try an OS reinstall first (being careful not to do the factory reset by mistake). This won't hurt your data, but might not cure your problem...
If they require a fee and you have a backup of your data, one alternative is to rebuild the NAS. This will wipe your data and config though. This can be done via the factory reset procedure. Or simply put the disks in a PC and delete the partitions ("volumes") via the disk manager (right-click on computer and choose "manage").
The boot menu is here: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu
Scroll down to the "Duo / NV / NV+ / X6/600" section.
Manuals can be found here: http://kb.netgear.com/app/answers/detail/a_id/20683
