benwrigley
Dec 15, 2013Tutor
Duo Performance and lockout
Hi All, I've been reading up a lot on performance issues that people are having but none seem to quite match mine. I apologise if I've writing about stuff already covered, but the performance troub...
Dec 19, 2013Guru - Experienced User
I'm not sure what your network topology is (or if you are streaming to the WD Live with dlna or CIFS/NFS). Just thinking that power-resetting the infrastructure might help. If the local traffic doesn't pass through the ethernet switch component of the R6300, then I agree that it is not likely to be the culprit.
