AdrianReady
Sep 29, 2014Aspirant
Duo V1 crashed #23954328
Please can someone help, My ReadyNas Duo V1 crashed yesterday (Sunday) and it has all my holiday and family photos on it for the last ten years. When I have a single drive in it Raidar sees the unit...
mdgm-ntgr
Sep 29, 2014NETGEAR Employee Retired
It may not be detected in SeaTools when you hook it up via USB.
It's possible you could have a bad chassis.
Do you another disk you could try in the Duo?
If you purchase e.g. a 312, you could contact support for assistance in recovering your data. Hopefully your disks and array are fine. You do need to be careful to follow the procedure they suggest if you do this (don't put disks in till it is suggested to do so etc.)
