AdrianReady
Sep 29, 2014Aspirant
Duo V1 crashed #23954328
Please can someone help, My ReadyNas Duo V1 crashed yesterday (Sunday) and it has all my holiday and family photos on it for the last ten years. When I have a single drive in it Raidar sees the unit...
AdrianReady
It was just a disk from the duo removed to an offsite location in case of a burglary or some such. I think it was a disk 2 but not sure.
Yes it says plenty of files are there but as its 1TB it will take a while to do the lot.
I've just ordered a ReadyNas 312 to replace the duo to see if that will read the drives.
I have put a new disk in the duo and raid says 4.1.13 in the info column but I can't login on the control panel to do a set-up. EDIT: default password worked.
But it can be seen on the network.
