AdrianReady
Sep 29, 2014Aspirant
Duo V1 crashed #23954328
Please can someone help, My ReadyNas Duo V1 crashed yesterday (Sunday) and it has all my holiday and family photos on it for the last ten years. When I have a single drive in it Raidar sees the unit...
AdrianReady
StephenB wrote: Linux Reader is free, you should not be asked to pay if you are using that. Are you sure you downloaded the correct utility? And are you sure you are seeing your data files, and not the OS files?
AdrianReady wrote: It may have been a disk 1 once as I thought all the raid array disks were interchangeable so I swapped them round every six months or so.
Linux raid recovery does say it can see files but I need to pay to get them back.
For the disk essentials it was the actually recovery of the files they were asking me to pay for, using the Raid Recovery tool.
I'll go and check Linux Reader.... no it won't read the disk and the properties says it is a Disk 2.
StephenB wrote: I didn't think you did. But swapping internal drives to make a backup is not a good method.
AdrianReady wrote: Sorry my poor use of the word backup, I didn't mean the Duo backup facility.
StephenB wrote: Nothing good. It either fails to boot or destroys your data.
AdrianReady wrote: A thought, what would happen if I put one of the old drives in with the new one as disk 1?
Okay, thanks. I thought Raid technology was supposed to copy things across seemlessly and automatically.
StephenB wrote: If you are prepared to pay, start by asking Netgear for a quote.
AdrianReady wrote: So any idea how much it would cost to recover the data professionally?
Or should I just pay diskinternals and see what that recovers?
Looks like I will need to go down that route then.
Whatever happens I'm not going to get anything working or recovered tonight.
