g262
Nov 21, 2012Aspirant
Duo v1: Dead volume
Am I correct in assuming that (a) the volume frontview and RaidAr say is dead, is not recoverable, and (2) that the data which was Raid-2 protected to the second still has a copy of my data? Thanks...
ReadySECURE
Nov 21, 2012Apprentice
Disk 1 appears to have failed out of the RAID.
According to these logs, it still detects your volume, so you should be able to access your volume and data.
I'm going to recommend at first to reboot your unit. It should re-detect the disk. From what I see here, you're using green drives, but the drives look fine to me. Green drives tend to drop out of raids because of their slow spin up time. Your first disk's start up time was 6300 while the second one was 3825, so the times were a little different when it came online. If it doesn't re-detect the disk and put it back in the RAID, turn off the unit, pull disk 1 (Device Model: WDC WD20EARX-00PASB0 Serial Number: WD-WCAZA8307523 <<< verify this disk serial) start the unit with disk 2 only, then pop disk 1 back in the unit.
