Hobban
Jan 06, 2014Aspirant
Duo v1 do not boot with 2 drives
After working without any problems for years including upgrade from 2x500Mb to 2x1Tb to 2x2Tb discs I got problems. It started with that I lost contact with my Duo v1. After spending some hours troubl...
Jan 06, 2014Guru - Experienced User
It sounds to me like a failing power supply (not enough power to spin up both disks).
I think if you google you can probably find a brick that is compatible.
