Hobban
Jan 06, 2014Aspirant
Duo v1 do not boot with 2 drives
After working without any problems for years including upgrade from 2x500Mb to 2x1Tb to 2x2Tb discs I got problems. It started with that I lost contact with my Duo v1. After spending some hours troubl...
mdietric
made a test a few minutes ago:
I have opened the casing on the Bay 2 side and have removed the plug of the chassis fan just for power-up. You won't believe it but the Duo v1 was booting with both drives installed! So StephenB seems to be right.
Can anyone recommend a suitable switching adapter? It seems that the standard 12V-switching adapter ist too weak (output: 5A). Will 6A (90W) be sufficient or do I have to take a 10A-version (100-120W)?
