Hobban
Jan 06, 2014Aspirant
Duo v1 do not boot with 2 drives
After working without any problems for years including upgrade from 2x500Mb to 2x1Tb to 2x2Tb discs I got problems. It started with that I lost contact with my Duo v1. After spending some hours troubl...
Jan 09, 2014Guru - Experienced User
Did you look here: http://www.wdc.com/wdproducts/library/S ... 771438.pdf
Peak power use for the WD10EZRX is spec'd at 1.2 A. If you are meaning an older model, perhaps you can check the WDC support pages.
