Monteverde
Jan 29, 2016Aspirant
Duo v1 hangs during sync and losses network
Hi, I have a ReadyNas Duo v1 with two 2 TB disks in RAID configuration (don't remember which), The 2TB disk space is almost full, ~95%. Maximum memory. I also have a UPS connected to the NA...
Monteverde
Jan 30, 2016Aspirant
Tried to boot up with only disk 2 plugged in.
The system came up after finishing the file checks, i.e. no hanging during fsck phase as with both disks or only disk 1 in.
So problem seems to be related to disk 1.
FrontView access, shares etc came up.
Did a controlled shutdown since I have to go away for a while.
Will try to backup to external disks from NAS during later tonight.
Jan 30, 2016Guru - Experienced User
Great. That simplifies the next steps (and you should have all your data).
The fastest way to back up your data is to attach the external disk to your PC and back up over a wired ethernet network. That is a lot faster than attaching the USB drives directly to the NAS. I like to use robocopy or teracopy, and not windows drag and drop. Teracopy has a verify option, which is probably worth using (though it will take longer).
Once that is done, install the replacement disk for disk 1. I like to test it with vendor diags in a PC first. Don't format it- just hot-insert it into the NAS unformatted. Keep in mind that your duo has a size limit of 2 TB or less. I recommend WDC Red drives (wd20efrx or wd10efrx). If you prefer seagate, use a drive from their VN line (not a DM drive).
The compatibility list for the duo is stale, so it isn't very useful anymore.
Obviously one lesson here is that RAID isn't enough to keep your data safe, so you should set yourself a regular backup schedule once everything is running again.
- MonteverdeFeb 03, 2016Aspirant
Hi StephenB,
Thanks a lot for the support!
Everything is now up and operational, a new disk1 (WD Red 2T). Backup schedule in place etc. I will also replace disk2 with a fresh WD Red just in case.
I would be very interessted in knowing the root cause to my problem. There are no traces in any of the logs that give any clues. Why is the NAS so sensible to problems during the checking of the filesystem? It doesn't seem like a robust system if problem with one disk makes the whole system freeze!
Since I have grown out of the current system I will also start looking for a replacement NAS.
Thanks again :)
- StephenBFeb 04, 2016Guru - Experienced User
You could PM mdgm, and ask if he is willing to go through your logs. His signature includes the procedure to get them to Netgear (which is emailing them).
- mdgm-ntgrFeb 08, 2016NETGEAR Employee Retired
Different disk can fail in different ways. In some cases a failing disk may lead to freezing. Without seeing your logs it seems that is what happened here.
