OBx2
Dec 18, 2013Aspirant
Duo V1 Power Timer
Readynas Duo V1 - Radiator 4.1.13
When I set the power timer to power off and then on, the power off never completes - the fan runs at high-speed continually (I've left it for a little over an hour before giving up). I have to power the unit off at the wall.
When I examine the log the last entry (before the "system is up" message after I've restarted the NAS) is e.g. "Wed Dec 18 15:50:21 GMT 2013 System power-on scheduled for 12/18/2013 16:05"
- vandermerweMasterDid it ever work properly?
Does it start to power off?
Do you have any add-ons running?
Have you tried an OS reinstall? - OBx2AspirantIt's never worked.
The device does power off - all the lights go off. It just never completes the power off (running fan).
DLNA and it behaves the same with no add-ons running.
Well, I don't know how to re-install the OS, but it's had at least two firmware updates over the years. - StephenBGuru - Experienced UserOS reinstall process is in the hardware manual - conveniently available for download here: http://www.readynas.com/download/docume ... 6Dec11.pdf
- OBx2AspirantReinstalled the operating system and the problem still exists.
