mattuk
Jul 04, 2015Aspirant
Duo v1 Radiator 4.1.14 Fan maxed out and wont recalibrate
I upgraded to Radiator 4.1.14. I then discovered that all my user accounts had been disabled and will not list in Frontview or allow me to re-create them because they already exist! The fan was running perfectly and quietly as it always has.
I did a factory reset and re-installed.
Since then the system fan is running at 5700rpm, the noise is excruciating, and the option to recalibrate the fan seems to be ignored after the ok confirmation message.
I've re-installed several times now using different disk drives as I ready somewhere that the fan controller uses the HD temp and wondered if that was an issue as I'd utilised a different and newer drive. I'm using Raid 0 JBOD if that makes any difference though it didn't previously.
I just installed the Beta Radiator 4.1.15-T3 and this made no difference.
Can anyone please help before my tinnitus gets any worse!
Thanks
Thanks
- mattukAspirantNow back at 4.1.13 but fan still running at max and won't callibrate :(
Hardware failure ?
Any ideas gratefully received.
Thanks - mdgm-ntgrNETGEAR Employee RetiredDo you have a backup of your data?
- mattukAspirantYes I do, it's all backed up. I've done factory reset several times now! So nothing to lose on the Duo at the moment.
- mdgm-ntgrNETGEAR Employee RetiredCan you send me your logs (see the Sending Logs link in my sig)?
- mattukAspirant
mdgm wrote: Can you send me your logs (see the Sending Logs link in my sig)?
Ok logs sent. - mattukAspirantI seem to have solved this issue. I had gone back to the beta Radiator 4.1.15T3 whether this relevant to the fix I don't know.
I had a look at the log files and found that the fan_setting_min file showed a value of 253 and the fan_setting_last a value of 255. Clearly there is a disparity between this and the actual speed of 5735.
I wondered if there is some built in logic that says if the these values are too low then run flat out for safety.
I found the add-on EnableFanMinRPMOveride and installed it. I thought that at least this would give these very low values a nudge into normality.
The default value in the add-on is 1600 so I chose 1500 to force a change if the 1600 default was set anywhere else. I did a re-calibrate on the fan and thankfully it worked and normalised the fan down to around 1560rpm. I reset the minimum again back to 1600 and recalibrated. After a reboot it all still works fine! - mdgm-ntgrNETGEAR Employee RetiredIt looks like the EEPROM on your system is messed up. This is rare on the Duo v1 but it can happen. Sent you a PM.
- bclayAspirant
Having the same exact issue.....can you please PM me what the fix is?
- markiiviAspirant
I am having the same fan issues described above; I have backed up the two 2TB drives which were in a RAID X config. I have removed those drives and replaced with a much solitary smaller drive in Bay 1; I have reinstalled Raidiator 4.1.14 for the second time and FACTORY reset twice too for good measure. The fan is running at 5769 rpm and will not recalibrate although the confirmation window does pop up to say it will do the job over next few minutes. May I please have the fix for this?
Many thanks
- petaAspirantHi!
I also got the same problem and if it's possible, I would like the information about how to handle it.
