willy134uk's avatar
willy134uk
duo v2 settings help
hi ive just install my readynas duo v2 probly a silly question but i cant find the settings for the ftp or any settings for that matter ive noticed on the site how to pics the frontview is differant to mine and has a dropdown menu with security options ect i dont have that?
thanks mark
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Is it just a problem with the add-on? If so you might be better to contact the add-on developer (when you purchased the add-on you should have got an email with an email address you can contact if you have problems).
  • not sure if the problem is only with the addon,il drag 5 gigs of data into the folder and see if it sends if it does then its a addon problem if not i guess all my media is going inside my os folder,if it was a addon problem surely it would show my other drive in the disk_log ? and not just the md0 folder
    mdgm-ntgr
    Yeah sounds like an OS issue not an issue with the add-on.
  • ok mate thanks for you help il try and reinstall while i wait for support to contact me
  • just to give you a update i formatted both my hdds then reinstalled with just 1 hdd and it seems fine now i have a c/ drive with 600+ gig and theres the seperate drive with the os on and all folder are in the right place,thanks for your help md
ProSupport for Business
