Skymac
May 30, 2015Aspirant
Duo2 reset
Hello I just bought a duo2 at an auction, therefore I do not have passwords. I need to reset it to start from scratch, any help and advice would he highly apreciated
vandermerwe
May 30, 2015Master
First check to see what duo it is - follow this guide:
http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
Then use the relevant boot menu instructions to do a factory default. Just google readynas duo v1 (or v2) boot menu and look at the Netgear knowledge base instructions.
You will need a disk in the nas when you do this and data on the disk will be wiped.
Once you have factory defaulted the unit the password will have been reset.
http://www.readynas.com/kb/faq/boot/wha ... ry_default
After you have done this I would suggest upgrading the firmware to the latest before doing anything else.
There is a large amount of information if you use google and/ or the Netgear manuals and kb.
http://www.readynas.com/download/docume ... 6Dec11.pdf
http://www.readynas.com/download/docume ... ept-11.pdf
Those are the hardware manuals for the v1 and v2. They have the boot menu instructions in them. There are separate software manuals.
I hope the unit is functional and you didn't pay too much for it. Users buying second hand are taking a risk.
