Skymac
May 30, 2015Aspirant
Duo2 reset
Hello I just bought a duo2 at an auction, therefore I do not have passwords. I need to reset it to start from scratch, any help and advice would he highly apreciated
May 30, 2015Guru - Experienced User
If you have a blank disk (new, or with no partitions) you can simply insert the disk into the NAS and power it up. The factory default will happen automatically.
However, you do need to know whether you have a v1 or v2 before you purchase drives, and the platforms have different default admin passwords.
Personally I like WDC Red disks (WD20EFRX is 2 TB, and will work in both platforms)
