Kenilik
Feb 07, 2012Aspirant
DUOv1 Upgrade from 1Tb to 2Tb
Hi, My situation is as follows: I have a DUOv1 with 2x1Tb disks in it (on the HCL) at about 85% capacity. X-Raid is configured and they mirror each other fine. I have had about 5 years of fau...
mdgm-ntgr
Feb 07, 2012NETGEAR Employee Retired
Well the disks you have chosen are 4k sector disks. Hence I recommend you read Why you might want to factory reset a Sparc ReadyNAS
