glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
ATCIS
Jul 01, 2013Tutor
fastfwd wrote: The -128 is certainly erroneous. The temp3 input is clearly not being used.
The 57-degree SYS temperature is probably right; is that how hot your Ultra4 ran when you were using RAIDiator 4.2.23?
Probably not, but I honestly don't remember without a shadow of a doubt. I may switch it to temp2_input even though 31 degrees C seems too low. On the GUI I have three thermometers: AUX = 40 C / 104 F, CPU = 43 C / 109 F, and System = 40 C / 104 F. Which leads me to believe that those graphical indications are also erroneous or I'm CAT'ing the wrong files. Wouldn't you agree that for a device residing in an 80 to 85 degree ambient environment that a System temperature of 134.6 F seems kind of high when the CPU temperature is only 109.4 F?
I've changed the script accordingly. It now looks like this:
#!/bin/sh
Coretemp="/sys/devices/platform/coretemp.0/temp2_input"
Systemp="/sys/devices/platform/it87.2576/temp2_input"
Ct=`cat $Coretemp`
C=`expr $Ct / 1000`
St=`cat $Systemp`
S=`expr $St / 1`
rrdtool update /run/readynasd/stats/temperature_int_deg.rrd N:$C:$S
Additionally, my /etc/crontab file now looks like this (perhaps my script file is okay, I just dorked up the crontab):
# /etc/crontab: system-wide crontab
# Unlike any other crontab you don't have to run the `crontab'
# command to install the new version when you edit this file
# and files in /etc/cron.d. These files also have username fields,
# that none of the other crontabs do.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
# m h dom mon dow user command
17 * * * * root cd / && run-parts --report /etc/cron.hourly
25 6 * * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
47 6 * * 7 root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
52 6 1 * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
# Delete the lines below if things get wacky. They are supposed to enable
# temperature graphing in the Frontview GUI. Good luck!
*/1 * * * * root /usr/local/etc/scripts/UpdateTempGraph.cron
You thoughts?
Thanks again!
Anton_
Dec 05, 2022Tutor
Need some help!
Running ReadyNAS 4 Ultra with OS6.
In the performance tab, the fan profiles silent, balanced and cool are ignored when i switch between them.
This worked with OS4 though.
I replaced the loud and noisy fan with a Noctua NF-A9 FLX.
The GUI reports correct RPM and temperatures for CPU and System.
But there are just no control of the fan it seems.
Included liblmsensors are using ULTRA4.conf as the configuration file.
system.conf -> /etc/frontview/sensors/ULTRA4.conf
- Anton_Jan 02, 2023Tutor
Any updates to this? Any solutions?
