glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
Iridabike
Jun 24, 2013Aspirant
Ok upgraded to 6.0.8 and the rrd files have been changed. New script is:
#!/bin/sh
Coretemp="/sys/devices/platform/coretemp.0/temp2_input"
Systemp="/sys/devices/platform/w83627ehf.2576/temp2_input"
Coretemp2="/sys/devices/platform/coretemp.0/temp3_input"
Ct=`cat $Coretemp`
C=`expr $Ct / 1000`
Ct2=`cat $Coretemp2`
C2=`expr $Ct2 / 1000`
St=`cat $Systemp`
S=`expr $St / 1000`
rrdtool update /run/readynasd/stats/temperature_int_deg.rrd N:$C:$S
Edit: There is a problem in 6.0.8 as readynasd also updates the rrd file and gives odd readings on the trend. I have made a hacked elf to stop it, but I would prefer to correct the temperatures it reads and let it update the file itself.
#!/bin/sh
Ct=`cat $Coretemp`
C=`expr $Ct / 1000`
St=`cat $Systemp`
S=`expr $St / 1000`
