glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
fastfwd
Jul 01, 2013Virtuoso
ATCIS wrote: When I did the - /sys/devices/platform/it87.2576# cat temp1_input
I got 57
When I -sys/devices/platform/it87.2576# cat temp2_input
I got 31
and when I -/sys/devices/platform/it87.2576# cat temp3_input
I got -128 (so I assumed that was erroneous)
I wound up using the temp1_input as the ambient room temperature is a about 85 degrees F and 87.8 degrees F for temp2_input seemed too low to me.
The -128 is certainly erroneous. The temp3 input is clearly not being used.
The 57-degree SYS temperature is probably right; is that how hot your Ultra4 ran when you were using RAIDiator 4.2.23?
ATCIS wrote: My resulting script looks like this: #!/bin/sh
Coretemp="/sys/devices/platform/coretemp.0/temp2_input"
Systemp="/sys/devices/platform/it87.2576/temp1_input"
Ct=`cat $Coretemp`
C=`expr $Ct / 1000`
St=`cat $Systemp`
S=`expr $St / 1`
rrdtool update /run/readynasd/stats/temperature_int_deg.rrd N:$C:$S
So do I need to do anything to make it GO? My temperature graph is still quite empty. . .
You stil need to modify your crontab, as described by Iridabike, in order to make the script automatically execute every minute.
ATCIS wrote: Any chance that the file in there named "systemd" is important?
Not to the syslog mystery, no. Unfortunately, I don't run OS6 so I can't suggest anything further. With luck, someone who does run OS6 will be able to tell you how to get syslogd running again.
