glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
sventunus
Sep 18, 2013Aspirant
Hi everyone!
I just updated my Ultra 6 from 6.0.8 to 6.1.2 and suddenly started getting fan alerts.
The OS6 GUI says my fan is dead. However, I can hear & see it blowing, and running "sensors" gives me the following output:
So the fan is actually running fine.
/etc/fancontrol looks like this:
Kernel:
I don't have any shell scripts running with a cron job though.
Should I have some script running to have my RN report correct fan status?
TIA!
Sven
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +47.0°C (high = +80.0°C, crit = +100.0°C)
Core 1: +47.0°C (high = +80.0°C, crit = +100.0°C)
it8721-isa-0a10
in0: +12.14 V (min = +9.41 V, max = +9.50 V) ALARM
in1: +5.00 V (min = +4.74 V, max = +0.87 V) ALARM
in2: +3.32 V (min = +0.83 V, max = +0.53 V) ALARM
in3: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in4: +1.14 V (min = +2.05 V, max = +1.33 V) ALARM
in5: +1.81 V (min = +1.42 V, max = +1.81 V) ALARM
in6: -12.10 V (min = +7.06 V, max = +2.04 V) ALARM
in7: +3.29 V (min = +3.38 V, max = +1.46 V) ALARM
in8: +3.38 V
fan1: 0 RPM (min = 16 RPM) ALARM
fan2: 0 RPM (min = 30 RPM) ALARM
fan3: 866 RPM (min = 15 RPM)
temp1: +0.0°C (low = +71.0°C, high = -20.0°C) ALARM sensor = thermistor
temp2: +0.1°C (low = +122.0°C, high = +59.0°C) sensor = thermal diode
temp3: +0.1°C (low = -1.0°C, high = -6.0°C) ALARM sensor = thermal diode
cpu0_vid: +2.050 V
# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/it87.2576
DEVNAME=hwmon0=coretemp hwmon1=it8721
FCTEMPS= hwmon1/device/pwm3=hwmon0/device/temp2_input
FCFANS= hwmon1/device/pwm3=hwmon1/device/fan3_input
MINTEMP= hwmon1/device/pwm3=51
MAXTEMP= hwmon1/device/pwm3=58
MINSTART= hwmon1/device/pwm3=40
MINSTOP= hwmon1/device/pwm3=40
MINPWM= hwmon1/device/pwm3=40
MAXPWM= hwmon1/device/pwm3=255
Kernel:
root@megapinnemuts:~# uname -r
3.0.87.RNx86_64.2.1
TIA!
Sven
