glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
spiderman1
Jan 29, 2014Guide
Hi guys,
I have now taken the plunge and installed OS6 on my Pro, however, I really need some guidance in terms of stabilising my fan control speeds as well as getting the temp graphs to work.
Thus far I have ready the forum posts and have done the following:
Step 1
Step 2
Used the powerconfig command as suggested http://www.readynas.com/forum/viewtopic.php?f=51&t=71155#p395324
Step 3
Here is the output after sensors:
Fancontrol file
I have modded by Pro with a q6600.
Any help would be appreciated.
Step 1
apt-get update && apt-get upgrade
apt-get install lm-sensors fancontrol
echo "#fancontrol" > /etc/fancontrol
Step 2
Step 3
/etc/init.d/fancontrol stop
/etc/init.d/fancontrol start
/etc/init.d/fancontrol restart
root@READYNASPRO:/sys/devices/platform/coretemp.0# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +27.0 C (high = +84.0 C, crit = +100.0 C)
Core 1: +27.0 C (high = +84.0 C, crit = +100.0 C)
Core 2: +21.0 C (high = +84.0 C, crit = +100.0 C)
Core 3: +21.0 C (high = +84.0 C, crit = +100.0 C)
w83627dhg-isa-0a10
Vcore: +1.14 V (min = +0.00 V, max = +1.74 V)
in1: +1.74 V (min = +0.84 V, max = +1.89 V)
AVCC: +3.20 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.20 V (min = +2.98 V, max = +3.63 V)
in4: +1.22 V (min = +0.38 V, max = +1.32 V)
in5: +1.49 V (min = +0.09 V, max = +0.30 V) ALARM
in6: +1.02 V (min = +0.95 V, max = +1.05 V)
3VSB: +3.17 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.07 V (min = +2.70 V, max = +3.63 V)
fan1: 1004 RPM (min = 42187 RPM, div = 8) ALARM
fan2: 0 RPM (min = 10546 RPM, div = 128) ALARM
fan3: 3125 RPM (min = 3375 RPM, div = 8) ALARM
fan4: 0 RPM (min = 5273 RPM, div = 128) ALARM
fan5: 0 RPM (min = 10546 RPM, div = 128) ALARM
temp1: +46.0 C (high = +127.0 C, hyst = +125.0 C) sensor = thermistor
temp2: +24.5 C (high = +80.0 C, hyst = +123.0 C) sensor = CPU diode
temp3: +19.5 C (high = +80.0 C, hyst = +123.0 C) sensor = thermistor
cpu0_vid: +0.000 V
Fancontrol file
#fancontrol
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS= hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/devic
FCFANS= hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/
MINTEMP= hwmon1/device/pwm2=30 hwmon1/device/pwm1=55
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=60
MINSTART= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINSTOP= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MAXPWM= hwmon1/device/pwm2=200 hwmon1/device/pwm1=80
