glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 << Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there! 6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000 ...
doc_dan
Mar 30, 2014Aspirant
Somehow I can't get the fans in my Ultra 6 to work. I tried a created /etc/fancontrol and tried to create it but the temperature sensors are missing.
sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: N/A (crit = +100.0°C)
Core 1: N/A (crit = +100.0°C)
it8721-isa-0a10
in0: +12.00 V (min = +9.07 V, max = +5.52 V) ALARM
in1: +4.96 V (min = +0.70 V, max = +4.07 V) ALARM
in2: +3.28 V (min = +0.36 V, max = +1.74 V) ALARM
in3: +0.00 V (min = +0.00 V, max = +0.00 V)
in4: +1.13 V (min = +2.96 V, max = +0.08 V) ALARM
in5: +1.80 V (min = +1.08 V, max = +0.58 V) ALARM
in6: -11.87 V (min = -39.23 V, max = -50.17 V) ALARM
in7: +3.26 V (min = +4.49 V, max = +3.53 V) ALARM
in8: +3.34 V
fan1: 2242 RPM (min = 2242 RPM) ALARM
fan2: 0 RPM (min = 693 RPM) ALARM
fan3: 2242 RPM (min = 12 RPM)
temp1: +0.0°C (low = -19.0°C, high = -109.0°C) ALARM sensor = thermistor
temp2: +0.0°C (low = +0.0°C, high = +0.0°C) sensor = thermal diode
temp3: +0.0°C (low = +19.0°C, high = -57.0°C) ALARM sensor = thermal diode
cpu0_vid: +2.050 V
# pwmconfig revision 6166 (2013-05-01)
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
Found the following devices:
hwmon0/device is coretemp
hwmon1/device is it8721
Found the following PWM controls:
hwmon1/device/pwm1 current value: 0
hwmon1/device/pwm2 current value: 0
hwmon1/device/pwm3 current value: 2
Giving the fans some time to reach full speed...
Found the following fan sensors:
hwmon1/device/fan1_input current speed: 0 ... skipping!
hwmon1/device/fan2_input current speed: 0 ... skipping!
hwmon1/device/fan3_input current speed: 2242 RPM
Warning!!! This program will stop your fans, one at a time,
for approximately 5 seconds each!!!
This may cause your processor temperature to rise!!!
If you do not want to do this hit control-C now!!!
Hit return to continue:
Testing pwm control hwmon1/device/pwm1 ...
hwmon1/device/fan3_input ... speed was 2242 now 2235
no correlation
No correlations were detected.
There is either no fan connected to the output of hwmon1/device/pwm1,
or the connected fan has no rpm-signal connected to one of
the tested fan sensors. (Note: not all motherboards have
the pwm outputs connected to the fan connectors,
check out the hardware database on http://www.almico.com/forumindex.php)
Did you see/hear a fan stopping during the above test (n)?
Testing pwm control hwmon1/device/pwm2 ...
no correlation
There is either no fan connected to the output of hwmon1/device/pwm2,
Testing pwm control hwmon1/device/pwm3 ...
hwmon1/device/fan3_input ... speed was 2242 now 0
It appears that fan hwmon1/device/fan3_input
is controlled by pwm hwmon1/device/pwm3
Would you like to generate a detailed correlation (y)?
PWM 255 FAN 2235
PWM 240 FAN 2220
PWM 225 FAN 2191
PWM 210 FAN 2149
PWM 195 FAN 2083
PWM 180 FAN 2014
PWM 165 FAN 1945
PWM 150 FAN 1859
PWM 135 FAN 1767
PWM 120 FAN 1670
PWM 105 FAN 1558
PWM 90 FAN 1436
PWM 75 FAN 1293
PWM 60 FAN 1138
PWM 45 FAN 960
PWM 30 FAN 6428 (probably incorrect)
PWM 28 FAN 502
PWM 26 FAN 502
PWM 24 FAN 503
PWM 22 FAN 504
PWM 20 FAN 504
PWM 18 FAN 505
PWM 16 FAN 507
PWM 14 FAN 508
PWM 12 FAN 508
PWM 10 FAN 508
PWM 8 FAN 506
PWM 6 FAN 503
PWM 4 FAN 500
PWM 2 FAN 0
Fan Stopped at PWM = 2
Testing is complete.
Please verify that all fans have returned to their normal speed.
The fancontrol script can automatically respond to temperature changes
of your system by changing fanspeeds.
Do you want to set up its configuration file now (y)?
What should be the path to your fancontrol config file (/etc/fancontrol)?
Loading configuration from /etc/fancontrol ...
Select fan output to configure, or other action:
1) hwmon1/device/pwm3 3) Just quit 5) Show configuration
2) Change INTERVAL 4) Save and quit
select (1-n): 1
Devices:
Current temperature readings are as follows:
cat: hwmon0/device/temp2_input: Resource temporarily unavailable
/usr/sbin/pwmconfig: line 892: let: S= / 1000: syntax error: operand expected (error token is "/ 1000")
cat: hwmon0/device/temp3_input: Resource temporarily unavailable
hwmon1/device/temp1_input 0
hwmon1/device/temp2_input 0
hwmon1/device/temp3_input 0
Select a temperature sensor as source for hwmon1/device/pwm3:
1) hwmon0/device/temp2_input
2) hwmon0/device/temp3_input
3) hwmon1/device/temp1_input
4) hwmon1/device/temp2_input
5) hwmon1/device/temp3_input
6) None (Do not affect this PWM output)
