chopin70
Apr 01, 2018Virtuoso
Enabling services for distinct ethernet interfaces
Hi, I want to separate access to the NAS inside my local network. My idea was to setup 2 different networks, either with 2 routers or using VLAN One network will have access to smb/ftp/ssh o...
- Apr 02, 2018
chopin70 wrote:
Would have been a great feature to make use of the dual NIC to separate traffic and services.
It has been asked for, but so far Netgear hasn't done it. It should be in the idea exchange somewhere.
There are a couple of related use cases -
- only allowing one NIC to access the NAS admin UI
- dedicating one NIC for iSCSI.
Having different network shares on each NIC would be pretty hard I think.
Apr 02, 2018Guru - Experienced User
chopin70 wrote:
Is it possible to make use of the 2 LAN adapters on the NAS to enable services on only one of the 2 interfaces ? Also, is it specifically possible to force DLNA broadcast on only one of the two LAN interfaces instead of teh two interfaces ?
It's not.
