mallisette
Jun 21, 2016Aspirant
Erro 300 in Readynas replicate
Getting a failed replicate between two RN314's both running 6.5.0 Exit code: 30 (Data send/receive timeout) The backup is over the local LAN. Any ideas?
JennC
Jun 21, 2016NETGEAR Employee Retired
Hello mallisette,
You might want to read this article: ReadyNAS: Replicate Troubleshooting
I also want to ask what account do you use to see the 2 NAS units via ReadyNAS Replicate site.
- mallisetteJul 20, 2016Aspirant
Last backup worked an no chages have been made!
Account in use is in the name of stratagem
This is a summary from a failed session:-
Summary:
Copy start time: 2016-07-09 18:57
Total files processed: 6084345
Total files transferred: 2006
Total files size: 15.89 TB
Total files size transferred: 24.67 GB
Average speed: 1.27 MB/s
Copy end time: 2016-07-10 00:28
Copy end time: 2016-07-10 00:29Many thanks
- HopchenJul 20, 2016Prodigy
Hi mallisette,
Can you copy/paste the latest log from the replicate portal please (for the job in question)? Rather than just the summary. So we can see more details.
Cheers!
Log:
2016-07-08 20:30:02 Job updated from server
2016-07-08 20:30:02 Replicate version: 1.3.0 build R2
2016-07-08 20:30:02 Starting backup job "Data Backup 2015-10-22 05h 23m PM "
2016-07-08 20:30:02 Locking target folder: /data/Documents/Data Backup 2015-10-22 05h 23m PM
2016-07-08 20:30:02 Previous lock detected
2016-07-08 20:30:02 Remove stale lock
2016-07-08 20:30:17 Resume folder is "/data/Documents/Data Backup 2015-10-22 05h 23m PM /2016-06-17 20-30 (failed)/data"
2016-07-09 18:57:22 p2p connect to REMOVED ****** network
2016-07-09 18:57:28 Connection method: 2
2016-07-09 18:57:28 LAN connection available
2016-07-09 18:57:28 Get LAN credentials
2016-07-09 18:57:28 Sending task to source device
2016-07-09 18:57:30 Awaiting task report
2016-07-09 18:57:32 Received success report
2016-07-09 18:57:32 Using LAN connection
2016-07-09 18:57:32 Initializing source device
2016-07-09 18:57:32 Sending task to source device
2016-07-09 18:57:33 Awaiting task report
2016-07-09 18:57:34 Received success report
2016-07-09 18:57:34 Device initialization finished
2016-07-09 18:57:34 Copy in progress
2016-07-10 00:29:52 Copy failed
2016-07-10 00:30:07 Deinitialize source device
2016-07-10 00:30:07 Sending task to source device
2016-07-10 00:30:09 Awaiting task report
2016-07-10 00:30:12 Received success report
2016-07-10 00:30:12 Device deinitialization finished
2016-07-10 00:30:12 p2p disconnect with REMOVED in ****** network
2016-07-10 00:30:13 Unlock target folder: /data/Documents/Data Backup 2015-10-22 05h 23m PM
2016-07-10 00:30:14 Job finished
Files:
[2016-07-09 20:17] Skipped 2000 lines
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7884.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7934.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7938.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7940.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7941.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/martin.jpg
Summary:
