mallisette
Jun 21, 2016Aspirant
Erro 300 in Readynas replicate
Getting a failed replicate between two RN314's both running 6.5.0 Exit code: 30 (Data send/receive timeout) The backup is over the local LAN. Any ideas?
JennC
Jun 21, 2016NETGEAR Employee Retired
Hello mallisette,
You might want to read this article: ReadyNAS: Replicate Troubleshooting
I also want to ask what account do you use to see the 2 NAS units via ReadyNAS Replicate site.
mallisette
Jul 20, 2016Aspirant
Last backup worked an no chages have been made!
Account in use is in the name of stratagem
This is a summary from a failed session:-
Summary:
Copy start time: 2016-07-09 18:57
Total files processed: 6084345
Total files transferred: 2006
Total files size: 15.89 TB
Total files size transferred: 24.67 GB
Average speed: 1.27 MB/s
Copy end time: 2016-07-10 00:28
Copy end time: 2016-07-10 00:29
Many thanks
- HopchenJul 20, 2016Prodigy
Hi mallisette,
Can you copy/paste the latest log from the replicate portal please (for the job in question)? Rather than just the summary. So we can see more details.
Cheers!
- mallisetteJul 20, 2016Aspirant
Log:
2016-07-08 20:30:02 Job updated from server
2016-07-08 20:30:02 Replicate version: 1.3.0 build R2
2016-07-08 20:30:02 Starting backup job "Data Backup 2015-10-22 05h 23m PM "
2016-07-08 20:30:02 Locking target folder: /data/Documents/Data Backup 2015-10-22 05h 23m PM
2016-07-08 20:30:02 Previous lock detected
2016-07-08 20:30:02 Remove stale lock
2016-07-08 20:30:17 Resume folder is "/data/Documents/Data Backup 2015-10-22 05h 23m PM /2016-06-17 20-30 (failed)/data"
2016-07-09 18:57:22 p2p connect to REMOVED ****** network
2016-07-09 18:57:28 Connection method: 2
2016-07-09 18:57:28 LAN connection available
2016-07-09 18:57:28 Get LAN credentials
2016-07-09 18:57:28 Sending task to source device
2016-07-09 18:57:30 Awaiting task report
2016-07-09 18:57:32 Received success report
2016-07-09 18:57:32 Using LAN connection
2016-07-09 18:57:32 Initializing source device
2016-07-09 18:57:32 Sending task to source device
2016-07-09 18:57:33 Awaiting task report
2016-07-09 18:57:34 Received success report
2016-07-09 18:57:34 Device initialization finished
2016-07-09 18:57:34 Copy in progress
2016-07-10 00:29:52 Copy failed
2016-07-10 00:30:07 Deinitialize source device
2016-07-10 00:30:07 Sending task to source device
2016-07-10 00:30:09 Awaiting task report
2016-07-10 00:30:12 Received success report
2016-07-10 00:30:12 Device deinitialization finished
2016-07-10 00:30:12 p2p disconnect with REMOVED in ****** network
2016-07-10 00:30:13 Unlock target folder: /data/Documents/Data Backup 2015-10-22 05h 23m PM
2016-07-10 00:30:14 Job finished
Files:
[2016-07-09 20:17] Skipped 2000 lines
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7884.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7934.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7938.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7940.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/_DSC7941.jpg
[2016-07-09 20:17] /data/Documents/DHS/2016/Staff Photos/martin.jpg
Summary:
Thanks for logs.
Ok so there is no problem with acutally connecting and initializing the job. It also correctly detects the LAN connection, that is good. It also does copy for quite some time. Over a peiod 5-ish hours it runs and copies. Eventually it seems to break down with a timeout.
From looking at the speed of the copy it seems to be very slow! 1.27MB/s (10.24 Mbit/s). This is on the LAN so surely it should be much faster? Are you running a full Gbit network? Or do you have 100 Mbit bottlenecks? From what I can see it is a huge job - 24+ TBs.
What if you simply transfer files manually from NAS to NAS. How fast is the speed? Also, check the destination NAS has plenty of free space left.
Lastly, are these NAS units always going to be on the same LAN? If so, you could use local rsync instead.
