TheUnknown
Aug 09, 2019Aspirant
Error Boot from USB
Boot from USB
Failed! i try to create a recovery USB stick, after the process is done the rn104 turns off, when i turn it on i get again the Message "Boot from USB Failed!" and i try also to st...
Aug 09, 2019Guru - Experienced User
Perhaps try again with a different thumb drive.
Why were you doing a USB recovery? Generally there aren't many problems that will solve.
- TheUnknownAug 09, 2019Aspirant
Behause yesterday i Turn The and off, today when i Start it cames directly the usb boot failed error
i create a usb Stick with creator and the latest os
- StephenBAug 09, 2019Guru - Experienced User
Are you saying that you just shut the system down yesterday (not changing anything), and that today the system is giving you the error boot message?
What USB devices do you have connected to the system?
Yes that is what i say, just shut down. nothing usb devisec, only network cable to router
