michelefaccini
Oct 01, 2011Aspirant
Error establishing a database connection
Hi,I get this error when I try to execute Wordpress install.php to complete the installation. Possible causes : Are you sure you have the correct username and password? Are you sure that you have...
michelefaccini
There's also the fact that in the How-To's procedure there is no password to access mysql prompt (see steps where you have to create the DATABASE wordpress),mine is password protected....the trick should be around there.....
