michelefaccini
Oct 01, 2011Aspirant
Error establishing a database connection
Hi,I get this error when I try to execute Wordpress install.php to complete the installation. Possible causes : Are you sure you have the correct username and password? Are you sure that you have...
sphardy1
Oct 01, 2011Apprentice
Have you followed these instructions: http://codex.wordpress.org/Installing_WordPress ??
If so, use phpmyadmin to login as the user you have defined to access the wordpress database - verify that you can in fact access it as that user and that the password is correct
