michelefaccini
Oct 01, 2011Aspirant
Error establishing a database connection
Hi,I get this error when I try to execute Wordpress install.php to complete the installation. Possible causes : Are you sure you have the correct username and password? Are you sure that you have...
polderviolin
Jan 20, 2012Aspirant
Hi Michelefaccini
It seems that I have semilars problems....
so please explain the last words(the GOT IT sentence):
- form phpMyadm ..is this in the php-config, or wich PHP / info file
- did you replace the 'localhost' in %
Maybe a picture of the file can tell a thousand words...
Thanks
polderviolin
Thanks
polderviolin
