michelefaccini
Oct 01, 2011Aspirant
Error establishing a database connection
Hi,I get this error when I try to execute Wordpress install.php to complete the installation. Possible causes : Are you sure you have the correct username and password? Are you sure that you have...
polderviolin
Feb 01, 2012Aspirant
Hi,
Anwer:
Directly after installation (and configure phpmy.. hostname nas-ip,socketadress, uid/pw mysql) I could login in PHPADMIN (and create a db) after that login by PHPMYADMIN fails: Error 1045.
So the problem:
- login by phpmyadmin (start in windows/frontview) comes with error 1045
- login db readynasphotos by MySQL ADMINISTRATION comes with error 1045
Further info for now:
! I'm able to access mysql by putty in SSH (and also there create a db)
! with "MYSQL Aministration" and "SQL Lite Manager" (both alternative for PHPMYADMIM) I can access the Wordpress database but not the other databases gives also error 1045
! I have already reinstalled php5 (5.3.8) + PHPMYADMIN (3.4.5)...change mysql pw to be sure that phpmyadmin use the same...
So I tried for a month to get phpadmin up & running (for wordpress) and I really need a helping hand/brain......
Anwer:
So the problem:
