michelefaccini
Oct 01, 2011Aspirant
Error establishing a database connection
Hi,I get this error when I try to execute Wordpress install.php to complete the installation. Possible causes : Are you sure you have the correct username and password? Are you sure that you have...
michelefaccini
Feb 06, 2012Aspirant
You wrote 'So the problem:
- login by phpmyadmin (start in windows/frontview) comes with error 1045...'
What do you mean by 'start in windows/frontview' ? You have to access you phpMyadmin from your web browser http://your NAS ip address/phpadm/.
From there you should set up permissions over the databases.
