michelefaccini
Oct 01, 2011Aspirant
Error establishing a database connection
Hi,I get this error when I try to execute Wordpress install.php to complete the installation. Possible causes : Are you sure you have the correct username and password? Are you sure that you have...
michelefaccini
Feb 06, 2012Aspirant
Otherwise you could grant permissions over databases accessing the nas with the putty shell....
Here's my 'config.inc.php' :
/* Servers configuration */
$i = 0;
/* Server: localhost [1] */
$i++;
$cfg['Servers'][$i]['verbose'] = '';
$cfg['Servers'][$i]['host'] = 'localhost';
$cfg['Servers'][$i]['port'] = '';
$cfg['Servers'][$i]['socket'] = '/var/run/mysqld/mysqld.sock';
$cfg['Servers'][$i]['connect_type'] = 'socket';
$cfg['Servers'][$i]['extension'] = 'mysqli';
$cfg['Servers'][$i]['auth_type'] = 'config';
$cfg['Servers'][$i]['user'] = 'root';
$cfg['Servers'][$i]['password'] = 'put here your password';
/* End of servers configuration */
$cfg['DefaultLang'] = 'en-utf-8';
$cfg['ServerDefault'] = 1;
$cfg['UploadDir'] = '';
$cfg['SaveDir'] = '';
Here's my 'my.cnf' file :
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = admin
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
skip-external-locking
skip-name-resolve
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
# bind-address = 127.0.0.1
skip-networking
innodb_buffer_pool_size = 6M
key_buffer_size = 16k
myisam_sort_buffer_size = 16k
max_connection = 20
# * Fine Tuning
key_buffer = 16k
max_allowed_packet = 16M
thread_stack = 128K
# * Query Cache Configuration
query_cache_limit = 1048576
query_cache_size = 32768
query_cache_type = 1
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
#log = /var/log/mysql.log
#log = /var/log/mysql/mysql.log
# The following can be used as easy to replay backup logs or for replication.
#server-id = 1
#log-bin = /var/log/mysql/mysql-bin.log
# See /etc/mysql/debian-log-rotate.conf for the number of files kept.
max_binlog_size = 16384
#binlog-do-db = include_database_name
#binlog-ignore-db = include_database_name
skip-bdb
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
$i = 0;
$i++;
[client]
port = 3306
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = admin
port = 3306
basedir = /usr
tmpdir = /tmp
skip-name-resolve
skip-networking
max_connection = 20
# * Fine Tuning
key_buffer = 16k
thread_stack = 128K
#server-id = 1
skip-bdb
# * InnoDB
[mysqldump]
quick
quote-names
[mysql]
[isamchk]
key_buffer = 16M
