aaron_25
Mar 06, 2017Aspirant
Error Messages
Bit of a newbie here I have a ReadyNAS10400 with one 3TB installed for now. The LCD screen is on and has Cannont Cennect Discovery Server but i have the desktop App for RAIDar and i can find ...
Mar 06, 2017Guru - Experienced User
The admin username is admin.
The default password is password. You are prompted to change the password in your initial setup, but the admin account name itself cannot be changed.
If you can't recall the admin password, you can try the OS reinstall procedure on page 27-28 of the hardware manual: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf?cid=wmt_netgear_organic
This will reset the password back to the default, and also reset the network configuration to the default (DHCP).
aaron_25
Mar 08, 2017Aspirant
Hi Stephen
thank you for your reply i managed to reset the password and i can now access it but on the screen it comes up with "Cannot cennect discovery server" i was wondering if you could help me once again.
many thanks
Aaron
- StephenBMar 08, 2017Guru - Experienced User
That message means it can't connect to the ReadyCloud server. ReadyCloud has been a bit unstable lately (based on several posts here). So it might not be the NAS.
Have you looked on the cloud page in the web ui? It should tell you if it can reach the internet and if the cloud service has been reached.
- aaron_25Mar 08, 2017Aspirant
i have the Ready nas plugged in to a powerline as its in a differnet room to my router and if my laptop is plugged into the powerline it finds it but as soon as i unplug it i cant find it at all?
Can you detail the path from the Readynas to your router?
