aaron_25
Mar 06, 2017Aspirant
Error Messages
Bit of a newbie here I have a ReadyNAS10400 with one 3TB installed for now. The LCD screen is on and has Cannont Cennect Discovery Server but i have the desktop App for RAIDar and i can find ...
aaron_25
Mar 08, 2017Aspirant
i have the Ready nas plugged in to a powerline as its in a differnet room to my router and if my laptop is plugged into the powerline it finds it but as soon as i unplug it i cant find it at all?
Mar 08, 2017Guru - Experienced User
Can you detail the path from the Readynas to your router?
- aaron_25Mar 09, 2017Aspirant
Router is in the living room and the ReadyNAS is in a spare room up stairs and are joined by the TP link Powerline adaptors.
in my laptop is plugged in to another power line it can pick it up but if i make it wireless it cant find it
- jak0lantashMar 09, 2017Mentor
The fact that the NAS can't connect to the ReadyCLOUD server is a problem only if you intend to use ReadyCLOUD. Otherwise, it doesn't really matter. If you can access the NAS locally, it means its IP address is OK. I can think of three reasons why the NAS can't connect to ReafyCLOUD:
1. Incorrect or missing default gateway on the NAS (if static IP).
2. Incorrect or missing DNS server on the NAS.
3. Filtering firewall.
- StephenBMar 10, 2017Guru - Experienced User
Get the ReadyNAS IP address (either from the LCD or from the router), and then try the wireless connectoin again - entering \\nas-ip-address into the address bar of file explorer. Use the real IP address of the NAS of course.
If that fails, try opening CMD on the laptop, and enter ping nas-ip-address and see if you get a normal response.
