flaviocb
Jan 05, 2018Aspirant
Error putname+64 & strlen+10 on RN104 after upgrading to 6.9.1 when doing aggregation eth0+eth1
I upgraded my RN104 system from 6.4.1 to 6.5.2 and then directly to ReadyNAS OS 6.9.1, everithing worked fine, but because I had to do a OS Reinstall while on 6.4.1 to revcover my password. Teh I ha...
- Mar 15, 2018
Hello, today I were able to update the FW to the ReadyNAS to 6.9.3 and I were able to do the Link Aggregation again. I used the option for the Adaptative Load Balancing and it worked fine. I just had a minor problem the 1st time I asked the RAIDar to open the Adminstratior web page, something was wrong and I had to manually put 192.168.0.114/admin/ so it worked perfectly.
I have one question about something that was mentioned in this thread: how much can I expect in average in performamce improvement by using the new functions implemented by Netgear ? (I understand that to get this advantage I have t reformat all volumes and reload the data)
Best Regards, Flavio
Mar 16, 2018Guru - Experienced User
My RN102 was running jbod from 2013, and about 2 years ago I was seeing about 35 MB/sec download speeds. A factory reset increased the speed to about 70 MB/sec.
You can benchmark your RN100 speed with NAStester ( http://www.808.dk/?code-csharp-nas-performance )
flaviocb
Mar 16, 2018Aspirant
Wow, it doubled the speed. I probably will do that reset procedure as soon as I will be sure I have 100% of my data bacled up in another storage. Thank you for the feedback.
- flaviocbMar 16, 2018Aspirant
Thank you for the tip about the utility to do the measurement. I am a MAc user, but I'll connect a Windows 10 machine and get the results.
- StephenBMar 16, 2018Guru - Experienced User
AFP might not perform identically to SMB, so you might want to try testing on the Mac also.
There are other techniques you can use - for instance, just measuring the time it takes to do a large transfer. NasTester uses that idea - the default settings transfer a 400 MB file to the NAS 5 times, and then reads it back 5 times. It reports the time of each transfer, and gives you the average.
Lan Speed Test ( https://totusoft.com/lanspeed ) does something similar, and there is a Mac version available.
