StefanoR70
Dec 18, 2017Aspirant
Error restoring from a snapshot
Hello, suddnbedly I cannot restore files/folders from snapshots, whn I try I have these events tin the log: Share: File restore from snapshot has started Share: LOGMSG_FSSNAP_RESTORE_FAILED Curren...
cs_giuseppe
Dec 19, 2017Apprentice
Hi,
do you have almost 30% free space?
Firmware 6.8.0 is quite old, I suggest to make/have a backup of the nas and upgrade to 6.9.1 that is more stable.
If the restore still fail there ia a problem with btrfs.
Dec 19, 2017Guru - Experienced User
I agree with both of these recommendations. I'd also download the logs and look at the SMART stats for drive health. kernel.log and system.log might give some more clues on why the restore is failing.
If your volume is very old, you might consider a factory reset/restore from backup after the upgrade.
