onrofla
Sep 24, 2017Aspirant
/etc/init.d scripts missing OS 6.8.0
Weird problem:
Two nearly identical RNDP6000/6 Pro
unit #2: new disks installed (prior to #1), installed OS 6.6.1, data copied, upgraded to OS 6.8.0, made config backup from frontview.
unit #1:...
mdgm-ntgr
Mar 08, 2018NETGEAR Employee Retired
Do you still have this problem?
You could try an OS Re-install or updating the firmware
