Jeff-Friend
Nov 08, 2018Aspirant
eth0 greyed out
Hi,
I have a RN31600 which is still in warranty.
I have noticed eth0 is greyed out on the Admin page. The link lights are on, on both the NAS and the switch and they are flashing like no...
- Nov 08, 2018
Hi Jeff-Friend
Welcome to the Community!
What firmware are you running? You can try to shutdown your NAS for a few minutes then boot normally, there had been issues with RN20 series NIC getting disabled but not with other models and shutting it down to cool down the NIC is a work around and it is now fixed on the latest firmware so if you are not on the latest updating it is also advisable. If you are not comfortable with SSH, you can try doing OS-Reinstall.
The link lights are on so the NIC should be enabled, hopefully it's not a hardware issue but since you are still in warranty and OS-Reinstall did not help, contacting Support is a good way to request for RMA i it is a HW issue.
Hope this helps!
Regards
Marc_V
Nov 08, 2018NETGEAR Employee Retired
Hi Jeff-Friend
Hope this helps!
Regards
- Jeff-FriendNov 08, 2018Aspirant
Hi,
I did a reboot about an hour after I posted the question an dnow both links are active.
Thanks for the replies and suggestions.
Jeff
