Gimpson
Aug 02, 2015Aspirant
Expand ReadNAS capacity by adding another NAS
Hi! I have a ReadyNAS NV2+, and am rapidly running out of storage space. I looked at buying a new 8-bay NAS (from various manufacturers such as QNap), but these see to be many times more expensiv...
- Aug 02, 2015
You can't link ReadyNAS ito create a single volume, so you'd need to run the two NAS independently. If you add network locations to windows file explorer (or create desktop shortcuts for different shares) this would be pretty transparent for the users.
Some NAS models do support an expansion module (an EDA500), but the NV+ v2 is not one of them.
Gimpson
Many thanks StephenB
I did wonder if it was even possible to do, so thanks for confirming. I'll have to look to an alternative solution, namely buying a new NAS I suspect.
Aug 02, 2015Guru - Experienced User
Getting a new/larger NAS and using the old one for backup is a reasonable approach too.
