wideef
Aug 07, 2015Aspirant
Expansion with X-Raid2, resulting sizes and different reported space on NVX Pro 4 unit / Frontview
Hello, We've got a Pro 4 with 4 x 3TB (WD30EFRX) drives, RAIDiator 4.2.27 and XRAID2 as single disk redundancy (SDR). We've expanded the unit over time (can't quite remember by how much and by whe...
- Aug 14, 2015
The addition of larger drives give us just a little more space (and time) to play with but I believe the only real solution here is a FR which we'll be working towards over the coming months.
Thank you very much though for all your help and suggestions.
Have a great weekend.
Aug 10, 2015Guru - Experienced User
I wouldn't recommend posting logs here, though sharing log snippets is often done. The way Netgear wants to receive logs is via email (the details are in mdgm's signature).
wideef wrote:
If we rule out the Snapshot theory then the MIT appears to point to a corrupt expansion somwhere along the line. We did indeed move from 2TB through to 3TB at some stage but by the sound of things the only risk-free way of really addressing this would be to carry out a FR.
Assuming an earlier expansion did fail - the issue here is that you've expanded again after that, using still larger disks. So the waters are a bit muddied.
wideef wrote:
Are there any good reads regarding the pros and cons of OS 6 vs Raidiator? We've been pretty happy with Radiator and the way it's worked for us with the exception of the expansion issue
There are some posts on the subject, unfortunately the subforum for OS6 on legacy devices on readynas.com wasn't carried over (though the posts are all here).
OS6 uses BTRFS as a file system, not ext. There is a performance hit for writes, but the snapshot feature is more powerful. It also includes built-in Antivirus (which can be turned off). The linux kernel is newer. ReadyCloud currently only works with OS6 (though Remote still works with OS 4).
One thing that is missing is the ability to send a WoL packet at the start of a backup job. Some add-ons for OS4 don't have OS6 app equivalents.
Personally I continue to run 4.2.x on my pro-6. But I am at the point where more expansion would take me over the 16 TiB ceiling. When/if I reach that point, I'll likely switch to OS 6.
wideef
Aug 14, 2015Aspirant
