Jojo90
Dec 24, 2015Tutor
External hard disk not recognized (either in USB nor eSATA) on my ReadyNAS104
Hello all ! I have a big problem : I bought an external dock (with USB and eSATA port), to archive the data of my NAS onto external hard disks. It always worked great with my old 2TB Western ...
Dec 24, 2015Guru - Experienced User
Does the dock work properly with 3 TB drives in your PC?
A lot of old docks don't handle disks > 2 TB.
- Jojo90Dec 24, 2015Tutor
Hello Stephen !
Yes it works well, even with my 4TB disks.
- mdgm-ntgrDec 28, 2015NETGEAR Employee Retired
It could be that the Linux drivers for the dock are not compatible with high capacity disks.
Shortly after connecting the dock, can you download the logs and send them in (see the Sending Logs link in my sig)?
