Jayce
Aug 18, 2016Aspirant
External USB Drive, write protected in EXT4 ???
Ok, so after having issues trying to use external USB disk to backup my ReadyNAS, i did some tests... If I format the disk as NTFS, it works OK read/write. It appears that if i format the disk a...
mdgm-ntgr
Aug 18, 2016NETGEAR Employee Retired
Which ReadyNAS model is this with and which firmware are you running?
