eton
Nov 22, 2012Luminary
Factory reset - workaround idea with double set of disks
I've just go an idea. Is it possible to first remove the disks and install another set and then make a factory reset of the unit and after that put the old disks back? Will that work? Will th...
Nov 22, 2012Guru - Experienced User
On an OS partition on the hard drives. Which is one reason why your idea won't work.
eton wrote: ...Where is the system stored on the nas?
Also, sometimes you need to destroy/rebuild the data volumes (for instance to achieve 4K alignment in an older V1 product).
